Find the discrepancies you need to locate using the filters on the left panel
or the top of the page. (See Find discrepancies for details on using the filters.)
Select one or more discrepancies. To select adjacent rows, press Shift
as you click rows (or press the down arrow key). To select nonadjacent rows,
press Ctrl as you click rows.
Tip:
You can skip the
remaining steps and use keyboard shortcuts to select Ready to Send to
InForm by pressing Ctrl+Alt+Q. Or, close one or more
discrepancies by pressing Ctrl+Alt+C. Use the down arrow keys to open
the drop-down list and select an option. Press Tab to navigate to
fields and enter a comment (if necessary). Press Tab to navigate to
Submit and press Enter.
From the Manage Discrepancies drop-down, select the action to take (for
example, Ready to Send to InForm). The drop-down list only includes
valid actions for the discrepancies you selected. A new dialog box with the name
of the action you selected opens in the right panel.
In the Reason field, select a reason from the drop-down list. Or, enter
reason in the Comment field instead. (If you select a reason and enter a
comment, Oracle DMW only saves the reason.
