Expand Default Listings, Custom Listings, or VC Listings.
Then, expand a clinical data model from the list.
Select a listing to open it.
In the appropriate row, select one or more data items where you want to create
a discrepancy. (You can select multiple data items if they all have the same
issue.)
Tip:
To select multiple data items, press the Shift or Ctrl key
while you select items.
Right-click and select Create Discrepancy. The Create Discrepancy dialog
box opens.
For the State, select Open (definitely a discrepancy) or
Candidate (possibly a discrepancy).
In the Discrepancy field, enter details about the discrepancy
(required). Then, fill in the remaining optional fields if necessary
(Category and Action you want taken [for example, Ready to
Send, Send to Spreadsheet, Needs Review]). To include a phrase set by you (for
example, your name), select Append User Name.
Click Create. Each selected data item appears with a discrepancy icon.
You can also see the discrepancy icon in the second column of the listing. For
details on the discrepancy icons, see View discrepancies in the Listings page.
