Expand Custom Listings in the left panel. Then, expand a clinical data
model from the list.
Select a custom listing to open it.
To locate a listing, enter part of a listing name in the Search
field and click the
Search icon.
Tip:
You can choose to show disabled listings by
selecting Show disabled CLs under the Search field. Oracle DMW disables listings if they read from a table that is not used
in the study.
You may need to scroll down to see Custom
Listings in the left pane.
To view deleted InForm data create a custom
listing, but do not install it. The system displays all records
that meet the criteria, including deleted records. After you
install it, the deleted rows are not displayed. For details on
creating a custom listing, see Create a custom listing.
