Select Custom Listing Manager from the drop-down menu to open the Custom
Listing Manager tab.
Click the Add icon from the Custom Listings header in the left panel to open the Add
Custom Listing dialog box.
Enter the appropriate information for the new custom listing in the Name
and Description fields.
Tip:
Use a name with 25 characters or less to avoid scrolling to
see the full name.
Select Authorize access to this listing for users without Blind Break
rights if you know that the listing only displays non-blinded data, even
though at least one source table contains blinded data. Take care to select
columns that do not contain blinded data.
If any source table is blinded in any way and this setting is
not selected, the system blinds the entire target table, so that only users
with Blind Break privileges can view any data.
Select Mark as Public to enable all data reviewers to use this custom listing.
Click Test to verify your custom
listing. After reviewing the Test
Results, click Close.
Click OK to close the dialog box and save the custom
listing with the details you entered. You can return to this procedure
and search for it to continue defining it later.
