Select Listings from the drop-down menu to open
the listings page. Expand a listing, expand a data model, and select
a listing. Then click the Filters tab from the left
panel.
Select Discrepancies from the drop-down menu to
open the discrepancies for the study you selected. The filter panel
appears on the left.
In the Saved Filters field, select the filter you want to delete. The
fields automatically populate with the criteria saved for the filter. For
example, if the filter used a formula, you see it appear in the Advanced
Filters field.
ClickDelete filter from the top of the Filters panel.
