Export data to Excel or CSV
After you select a study and open a listing, you can export the data. To export the data in a listing, click Export from the top of the listing table to open the Export Listings options.
You can select one of the following export options:
Excel: Generates an .xls file that includes all the data that satisfies the current filters (if any are used).
If the record set you are attempting to export contains more than one million rows, you must use the .csv format. -
CSV: Generates a comma-delimited text file that includes all data that satisfies the current filters (if any are used).
Clicking the Export button generates a background job that compiles the listing into the selected file type, allowing you to continue working in other parts of DMW while the export is processing. When the export is ready, you are prompted to download the file to your computer.
Export History
The Export History section of the window retains a record of listing exports requested in the last 24 hours, up to a maximum of 25 Exports per study and lifecycle.
