How do I send these discrepancies to the lab?
You can use Export All to Excel to export discrepancies to a spreadsheet and manually send them to the source lab. Lab personnel can then respond or change the underlying data item and load the changes into DMW, and you can act on the discrepancy in DMW.
When you use the Export All to Excel option to send discrepancies to a spreadsheet, all discrepancies that meet the current filter criteria are included, even if they are not visible on the screen.
Parent topic: Lab data discrepancy FAQs
