Select a lifecycle stage
Oracle DMW opens in the lifecycle stage you used in your last session. To change it, select a different stage from the Lifecycle drop-down menu at the top of the data shown within the Home, Study Configuration, or Data Management page. The stages you can choose are:
Development. For studies and objects getting created or modified. When you check out an object, the new version is in Development.
Quality Control. For studies and objects being tested. It corresponds to UAT in InForm.
Production. For production data in live studies.
The lifecycles displayed to you depend on your account privileges so it's possible that you may only have access to one or two stages.Parent topic: Basics
