To view data and create discrepancies, click
Listings. To see custom listings or validation check
(VC) listings, scroll down the left panel and expand a data model.
To review and act on discrepancies, click
Discrepancies.
To view how the data flows between the input model and the
target model, click Data Flow. For example, a flow diagram shows
the mapping between the models and indicates the success or failure of
the data flow. It also indicates any warnings within the flow.
To create or manage custom listings, click Custom Listing
Manager.
