Use the search fields at the top
You can enter a partial value here to find all records that contain that value. For example, if you search for Subject ID=CA, you find all subject IDs that contain CA, unlike the filters that find only the exact value entered.
If there are filters in effect when you search in these fields, the system applies the filters and searches on these values within the filter results.
If there are no filters in effect, the system searches across all discrepancies.
Tip:
To see which filters are in effect, click the down arrow in the Filter: ON indicator at the top of the page.
After you select a study, click Data Management in the navigation bar.
For details on selecting a study, see Select a study from the Home page. -
Select Discrepancies from the drop-down menu.
In the drop-down list above the discrepancies table, select what to search on, for example: Category, Datasource, Days since last state change, Validation check. The choices depend on the columns your organization uses.
Tip:
You can skip the remaining steps and use keyboard shortcuts to access the Search field by pressing Ctrl+Alt+S. Press Enter to open the Search field drop-down list of available columns you can search. Use the arrow keys to select the column name. Then press Tab to navigate to next field and enter a value. Press Enter to find the data under the criteria you specified. -
Enter a value in the text box.
Click the Search icon.
- To clear the filters, remove the value entered in the text box and click Refresh from right of the navigation bar.
Parent topic: Find discrepancies
