What do the different TMS Discrepancy Categories mean?
TMS in Progress prevents updates in DMW while the data item (term) awaits manual classification in TMS.
TMS Evaluation means that the item or discrepancy has been updated either in the source system or in DMW, and triggers autoclassification on the term in TMS during the next transformation. No updates can be made in DMW while the category is TMS Evaluation.
TMS DM Review means that the data manager should review the discrepancy in DMW.
TMS Inv Review means that the discrepancy has been sent to InForm as a query for review by the investigator. The system also sends any subsequent updates to the discrepancy to InForm.
You can use a Discrepancy Categories filter to help process these discrepancies.
Parent topic: TMS discrepancy FAQs
