Set Up Logging
After you deploy the Oracle DMW application (dmwapp) as described in Deploy Oracle DMW on the WebLogic Server, follow these steps to enable logging for dmwapp at the INFO level.
Check that you perform these steps whenever you need to restart the managed server. The system you use depends on where you deployed Oracle DMW (for example, WebLogic Server or Oracle Enterprise Manager). This procedure uses Oracle Enterprise Manager (OEM).-
Log in to the managed server where you deployed Oracle DMW (for example, OEM).
From the Server section, select the managed server where you deployed Oracle DMW.
- From the WebLogic Server menu, select Logs > Log Configuration.
- Expand Root Logger, locate dmwapp, and select Notification: <#> (INFO) from the Oracle Diagnostic Logging Level (Java Level) column.
- Click Apply.
If you deployed Oracle DMW to more managed servers, repeat steps 2 through 4 for each server.
Parent topic: What's Next
