7 What's Next
After you have finished all the installation tasks in this book, you must do the following tasks before you can begin to use the Oracle Health Sciences Data Management Workbench (Oracle DMW).
You perform most of the following tasks in Oracle Life Sciences Data Hub (Oracle LSH):
- Set Up System Security
- Set Up User Security
- Set Up Oracle LSH Services
- Assign User Group to InForm Family Adapter
- Set Up OAuth for InForm and Oracle DMW Integration
- Enable rng-tools to Avoid Performance Issues While Sending Discrepancies
- Set Required Profile and Lookup Settings
- Create Study and Library Categories in Oracle LSH
- Set Up File Watcher
- Set Up Logging
- Integrate Other Applications (Optional)
