Set the TZ Environment Variable Automatically
You can set the TZ environment variable automatically by one of the following methods:
- Set the TZ variable in the startup configuration file (.profile or .cshrc file) for the operating system user that runs the DP Server process or the WebLogic Server process on the respective middle tier.
- Set the TZ variable in the shell script that starts the process:
- For the DP Server, set the TZ variable in the DP Server Home/cdr_apps_dpserver.sh shell script, or in a shell script that invokes cdr_apps_dpserver.sh; see the Oracle Life Sciences Data Hub Installation Guide for information.
- For the WebLogic Server, set the TZ variable in the setDomainEnv.sh script from your WebLogic installation in a full path similar to middleware_home/user_projects/domains/base_domain/bin/setDomainEnv.sh.
To determine a valid TZ value, see Use the tzselect Utility.
Parent topic: Configure Server Time Zone Settings
