Set the TZ Environment Variable Manually
You can set the TZ environment variable as follows:
TZ='<correct timezone>'export TZ
For example, to set the time zone to the US Pacific time zone:
TZ='America/Los_Angeles'export TZ
To determine a valid TZ value, see Use the tzselect Utility.
Parent topic: Configure Server Time Zone Settings
