Check out a data model to remove or update its business areas
Recommendation: If you need to modify a business area (BA):
Check out its associated data model in the Development lifecycle.
Update the data model in the Development lifecycle.
Install the changes in the Development lifecycle.
Promote and install to QC and Production, as needed.
Rationale: A business area is a property of a data model, and you can only change it by creating a new version of the data model.
Additional information: Avoid modifying the business area schema in the LSH user interface. This is consistent with recommendations In DEV and QC, run a full data model installation only to revert destructive changes and Install and promote data models after every change.
Parent topic: Clinical data models
