Copy blinded validation checks to blinded tables
Recommendation: Copy blinded validation checks to blinded tables and non-blinded validation checks to non-blinded tables.
Rationale: Columns in a VC listing retain the blinding properties of their underlying data model. If there is a mismatch between the blinding of the validation check and its tables, DMW will report errors.
Additional information: We recommend that you define libraries with a blinded and unblinded validation check definition. You can then copy the validation check with the appropriate blinding setting for your purposes.
Parent topic: Validation checks
