Copy valid validation checks
Recommendation: Avoid copying validation checks that are disabled or that require an upgrade.
Rationale: Validation checks that require an upgrade might not include necessary columns from the data models, or have other un-resolvable issues.
Additional information: We recommend that you only copy validation checks from approved templates or study libraries. In addition, if a validation check is deprecated, we recommend that you put in place a documented process to make sure that they aren't propagated to other studies.
Parent topic: Validation checks
