Verify the validity of a validation check batch before you copy it
Recommendation: Before you copy a validation check batch, to make sure that it's valid, verify that the columns in the source data model exist in the target data model.
Rationale: DMW allows you to copy a validation check batch that does not have valid columns in the destination data model. We recommend that you ensure that the validation check is valid before you copy it.
Additional information: We recommend that you only copy validation checks from approved templates or study libraries. In addition, if a validation check is deprecated, we recommend that you put in place a documented process to make sure that they aren't propagated to other studies.
Parent topic: Validation checks
