Re-load study data after each round of testing
Recommendation: If you integrate InForm UAT or TRN studies with DMW in the Development or QC lifecycles, re-load study metadata after each round of testing to ensure that you are always using the latest study version.
Rationale: InForm UAT or TRN studies might contain columns that don't exist in the Production study, or column properties that differ substantially. If there is a mismatch between the metadata in DMW and the metadata in the study's database, DMW doesn't allow you to promote the study to the Production lifecycle.
Additional information: You can run the Meta Data Difference Report to determine if there are differences between the InForm Production database and the InForm data model in the DMW QC lifecycle.
Parent topic: InForm integration
