2 InForm integration
- After a LIVE deployment, do not remove forms or items from your InForm study
- After a LIVE deployment, do not modify form or item RefNames
- Re-load study data after each round of testing
- Keep the InForm data model in sync between the Development and QC lifecycles
- Do not promote standard libraries or templates to Production
- Run a full data model installation after an InForm UAT study reset
