Do not perform tasks in the DMW_DOMAIN work areas if check out required
In general, do not perform a task in the DMW_DOMAIN work areas if the task requires you to check out a work area as described:
Recommendation: The exception to this rule is any task that requires you to check out a work area that is used for a custom function, and the work area exists in an application area in the DMW_UTILS sub-domain.
Rationale: DMW cannot anticipate its underlying database objects being checked out from outside its application. The unexpected object states cause system instability.
Additional information: Only perform actions in the DMW_DOMAIN under direct instruction from Oracle Support or Oracle Product Engineering when they determine it is necessary for the resolution of a Service Request.
Parent topic: General recommendations
