Compare DMW and Clinical One Metadata
You can compare the metadata—table and column structure—in any DMW Clinical One model lifecycle stage to any Clinical One lifecycle database for the same study.
  1. Click the Study Configuration icon Shows gear with pencil iconfrom the navigation bar. Then click the Clinical Data Models tab.
  2. In the clinical data model Clinical One Configuration tab, click the Icon is a square with stripes.Compare DMW and C1 Metadata icon.
  3. In the Metadata Comparison window, select the lifecycle metadata to compare in DMW and Clinical One.
  4. Click Compare.
    The report appears on screen.
  5. To save the report, click the Icon shows a paper with an X and and arrow out.Export All to Excel icon.
