Load Clinical One metadata
  1. Click the Study Configuration icon Shows gear with pencil iconfrom the navigation bar. Then click the Clinical Data Models tab.
  2. Select Development from the Lifecycle drop-down at the top of the page.
  3. Select the Clinical One clinical data model and click Check Out.
  4. In the Clinical One Configuration tab, click the Icon is two parallel vertical lines.Suspend Data Load icon.
  5. Click Icon is a folder and an Up arrow.Load Clinical One Metadata. In the Development lifecycle, this process includes installing the model.
  6. Click Icon is a near circular arrow.Refresh and check the Status column.
  7. Click Icon is a forward arrow triangle.Resume Data Load.
