Modify a Clinical One input model
The Clinical One model must have exactly the same table structures as in Clinical One. You cannot make any structural changes.
Tip:
You can change attributes that apply only in DMW, but if metadata is reloaded from Clinical One either manually or automatically, your manual changes are lost. See Load Clinical One metadata for more information.Parent topic: Modify a clinical data model
