Configure column labels and column descriptions for the product-event combinations tables
Signal summary columns appear on the product-event combinations table. When Signal management is set up for your organization, you can edit the column headers and tooltips for the product-event combinations tables.
Field descriptions—Edit Product-Event Columns dialog box
Field | Description |
Column name |
Name of the column on the Product-Event Combinations page. The name can appear in the tooltip when you hover on the column header if [%COLCODE] is included in the column description. |
Column description |
Description of a column on the Product-Event Combinations page. The description appears as a tooltip when you hover on the column label. |
Column label |
Text to appear as the column header on the Product-Event Combinations page. |
Parent topic: Set up for interactive signal management and review
