User Guide and Online Help Settings and administration System configurations Manage signal configurations Set up for interactive signal management and review Modify the display order of product fields Modify the display order of product fields In the left navigation pane, click the Settings icon (). From the Configure System menu, select Manage Signal Configurations. Select the signal configuration and, from its Row Action menu (), select Edit Product Fields. In the top left corner, click Modify Display Order. To change the order in which fields display in the Edit Product Fields table and in the Add/Edit Product window, click a field and: Click to move the field up in the list. Click to move the field down in the list. When the fields are in the correct order, click OK. Parent topic: Set up for interactive signal management and review
