Enter a note about a product
You can enter or edit notes about issues that have been identified and investigated for the product, signals that require further evaluation, or any information you want to associate with the product.
To view the note, select that product row on the Products table and click the right arrow to the left of the Notes heading in the Detail panel on the right, or select View Notes from the product’s Row Action Menu ().
Parent topic: Focus on a single product from the Products table
