- User Guide and Online Help
- Review signal information
- Step 3: Investigate product-event combinations for a product
- Investigate product-event combinations for a product
The Product-Event Combinations panel is a set of tables, accessed by
clicking a Product-Event Combinations tab. Each tab represents a view of the
Product-Event Combinations assembled from the current Refresh runs, as well as rows
from previous refreshes which have either unreviewed alerts or comments. By default,
there is a tab for each active alert type and each additional tab defined by a view.
You can add
more tabs using the
icon on the right.
- In the left navigation pane, click the Signal Review
icon (
). - (Optional) From the Products By drop-down list, select a product grouping, then select a card to filter the Products table.
- Click the product's Row Action Menu (
) and select View Product-Event Combinations, or
click the product name or total count.The Product-Event Combinations page appears.
- (Optional) Select a System Organ Class (SOC) card to filter the Product-Event combinations table.
- View product-event combinations for an alert type. Click an alert type tab at the top of the table, such as DME. The Product-Event Combinations table displays combinations that raised the alerts of this type in the current refresh, as well as unreviewed alerts raised in a previous refresh, all filtered by SOC selection. The columns reflect the alert type's view. By default, for each combination, the table shows the product, event, status, alerts, statistics, and comments columns.
- Select a row to update the Detail panel. You can review Recent History, Signal Statistics, Subgroup Statistics, and Associated topics for the selected product-event combination.
- View cases
and reports. Some values in the table are links to a menu for
drilling down to case information and reports. Most case counts presented in the
table support drilling down for detailed information and open a menu to view or
perform operations on the underlying set of cases. Numbers with this capability
are displayed in bold, and a down-arrow appears when you hover over the
field.
- View Cases: Lists cases associated with the count shown in the table. The information shown is customizable through the data configuration. On the View Cases page, if you click the case ID or the value in the ISR column, the Case Details page displays with the case information. You can select Next or Prior to move to the next or previous case in the series.
- Create Case Series: On pages and in reports that
display a list of cases identified by case ID, you can save the list of
cases for future use. The named and saved list of cases is referred to
as a
case series. - Transfer to Case Series: On pages and in reports that display a list of cases, you can transfer cases to an existing case series.
- Download Cases: When you view a table of cases, you can download the information to various types of files.
- Download Case Details: When you view case details, you can download the information to various types of files.
- Reports: This choice displays a list of available
reports. To run the report, select a report, click the Row
Action menu (
), and select Run.
- To customize the columns in the Product-Event Combinations
table, click the Header Action menu (
) and select Columns. You can select columns to
include, reorder them, and sort the table using up to three different columns.
See Product-event combination columns. - To download
the Product-Event Combinations table, click the Header
Action menu (
) and select Download. You can specify a file
name, the format to use, the maximum number of rows, and create a Zip archive
file. - To apply
Row Action menu choices to multiple rows of the Product-Event
Combinations table, click the Header Row menu (
) and select Select Rows. Then select the checkboxes of the rows to
include. Click the Header Action menu (
) and select the action to perform on all the selected rows. - To save
your selections as a view that you can reuse, click the
) and select Save As View. The saved view is
available under the Add Tab (
). A signal view specifies the following for the Product-Event
Combinations page:- Which columns are included.
- The sort order of columns.
- The SQL WHERE clause (if any) that applies selection criteria to product-event combinations.
- Perform additional actions on this product by choosing an action from the
Row Action menu (
):- Submit Review: Review a product-event combination, add a comment, and associate a topic (optional). If the product-event combination had unreviewed tracked alerts then, upon completion of Submit Review, the tracked alerts are considered reviewed and alert reviewed counts are updated.
- Edit Topic: If the product-event combination has been reviewed and associated with a topic, edit the associated topic.
- Add Comment: Add a comment visible to all for the product-event combination.
- Add Private Comment: Add a comment visible only to you for the product-event combination.
- Assign Reviewer: Select a reviewer for the specific product-event combination.
- View Signal History: Display a graphic and detailed summary of the statistics associated with the product-event combination.
- View Similar Combinations: View the statistical information for combinations involving the same product and the same HLT, HLGT, or SOC as that of the PT in the original combination.
- View Interactions: Information about an event and product interactions is represented as a nested confidence interval graph of EB05-EB95 confidence intervals and EBGM values for two products and the event.
- View Age Group Breakdown for a Signal Set (such as All): The breakdown of case data by age group or gender for a product-event combination is represented in a bar graph.
- View Gender Breakdown for a Signal Set (such as All): The breakdown of case data by gender for a product-event combination is represented in a bar graph.
