Keyboard shortcuts for the Products and Product-Event Combinations tables
- To interact with the Products and Product-Event Combinations tables:
- To set focus to the table, press Tab or Shift+Tab.
- To navigate up or down rows in the table, press the Up or Down arrow.
- To display the row action menu when a row has focus, press Enter.
- To select a menu item, press Enter.
- To dismiss the menu, press Esc.
- To interact with cells in a row in the table:
- To restrict focus within a table row, press F2.
- To focus on the next or previous cell, press Tab or Shift+Tab.
- To select a link or display a menu in a cell that is in focus, press Enter.
- To turn off navigation within a table row, press F2 again.
- To interact with the table header:
- To navigate to the table, press Tab or Shift+Tab.
- To navigate to the table header, press the Up or Down arrow.
- To display the header action menu, press F2 and Enter.
- To dismiss a menu item, press Esc. To set focus back to the table header, press Esc again.
- To navigate between header cells, press the Left or Right arrow.
- To sort a table column, press Enter.
- To interact with the select rows mode in the Product-Event Combinations table:
- To restrict focus within a row, press F2.
- To check or uncheck a check box, press Space.
- To exit focus from within a row, press F2 again.
- To check or uncheck other rows, repeat steps above.
Parent topic: Review signal information
