Start with the Signal Review pages
The Oracle Empirica Signal Products and Product-Event Combinations pages summarize alert information and track review of alerts for products and product-event combinations in a visually intuitive and interactive manner.
Two pages provide your entry into all Oracle Empirica Signal review functions:
- Products is your first entry into Signal Review. The
Products page shows a summary of the monitored products and alerts and it is
where you can narrow your focus to a single product.
The Detail panel on the right graphically depicts tracked alerts, informational alerts, event combinations with open topics, and recent notes. This panel changes with your Products By and card selection and your Product selection. You can collapse and expand the sections.
- Product-Event Combinations show product-event combinations
for the selected product and selected System-Organ class (SOC) card. The cards
are used to group the product-event combinations and display Reviewed/Total
counts for tracked alerts aggregated by SOC. Select an SOC card to filter the
product-event combinations by SOC. Tabs with the alerts are displayed below the
cards. Tabs associated with tracked alerts show the number of product-event
combinations for the alert. Select a tab to display the product-event
combinations table for the tab.
The Detail panel on the right graphically depicts Recent History, Signal Statistics, Subgroup Statistics, and Associated topics for the selected product-event combination. Topics appear only if your configuration is integrated with Oracle Empirica Topics. You can select different variables to graph, such as All EB05, Age Group, or Gender, using the drop-down lists in the Signal Statistics or Subgroup Statistics sections. To perform further actions on the data associated with a bar or donut slice, click the bar or slice to display the Action menu. You can select View Cases or other actions related to case series and reports.
For the Products and Product-Event Combinations tables, the cards summarize the number of tracked alerts that have been reviewed and the total count of alerts.
Use the Header Action Menu (
) on the table to access functions such as adding and removing columns. Use
the Row Action menu Row Action Menu (
) to access functions specific to the table row.
Display the Products and Product-Event Combinations pages
Parent topic: Review signal information
