Maintain signal views
A signal view specifies the following for the Product-Event Combinations table:
- Which columns are included, and in what order.
- The sort order of columns.
- The SQL WHERE clause that selects product-event combinations (shown on the Rename Signal View page).
Typically, an organization has predefined standard views. Additional views can be added by the user by the Save a product-event combinations as a new view option.
Users with Manage Signal Views permission are able to open Manage Signal Views page. They can organize, publish, rename, and delete views created by the user, views created by other users in their login group, as well as views published to their login group.
Users without Manage Signal Views permission are able to open Manage Signal Views page. They can rename and delete views that they created.
- Rename, publish, or delete a view
If you click the Row Action menu () for a signal view, you can do the following:
- To rename a view, click Rename.
- To publish a view, click Publish,
select the login group(s), then click
Back.
This option is available only if you have the Manage Signal Views permission.Prior to publication, signal views are visible only to their creators and to superusers. If you are a superuser, you can publish to multiple login groups, including —All–. In the Publish to Login Groups drop-down list, click or Ctrl+click to select login groups. If you publish to —All– and later add a new login group, the object is published automatically to the new login group.
- To delete a view, click Delete and then click OK.
For information about viewing, printing, or downloading tables or changing the way data displays in the table, see About tables.
Parent topic: Manage signal views
