In the left navigation pane, click the Signal Review
icon ().
From the Manage Reference Data menu (), on the top right, click Manage Views.
Click the Row Action menu () for a signal view, and then click Rename.
In addition to the information you can change in
the steps below, the Rename Signal View page shows the following information
about the view:
The
ordered list of columns included on the Product-Event Combinations page.
The
sort order for the Product-Event Combinations table.
The
SQL WHERE clause, if any, that selects the product-event combinations
to appear in the Product-Event Combinations table.
In the View name field, enter a new view name.
In the Description field, enter an informative
description of the view.
Optionally, change the Category assignment for the
view.
To add the view to an existing category, select
Add to existing category and select the view
from the drop-down list.
To add a new category, select Add to a new
category named and type the category name in the text
box.
Optionally, change the Review period for the view by
selecting it from the Review period drop-down list. This
option is available if the signal configuration has the review period feature
set up.
If you change the review period, the review period alerts will not display
as expected until the next refresh.
