Manage the columns on the Topics and Actions tables
You can add and remove columns, reorder columns, and sort columns.
The Header Action menu ( ) on the Topics and Actions tables has a Columns choice. It allows you to add selections from the Available Columns list to the Selected Columns list, add and remove columns, reorder columns, sort columns, and specify the order in which the columns appear in the tables.
