Work with topics
This section includes procedures for working with topics and topic reports.
- View topics
You can view topics you created and topics you have permission to see from your work teams. - Filter the Topics table
Use the Select Filter button and modify filter values to filter the content of the Topics table. - View a specific topic
You can view general information about a topic and the topic links, comments, attachments, actions, and history associated with the topic. - Quickly access topic information
If you click on any row in the Topics table, the Recent Topics panel is replaced with a Detail panel with details about the selected topic. - Open a topic from the Recent Topics list
If you click a topic in the Recent Topics list, it opens for viewing. - View Topic and Edit Topic pages
From the Topics table, you can view and edit topic information. - Edit the general information about a topic
On the Edit Topic page, you can make changes to the general information about a topic. - Add or view comments for a topic or action
You can add or view comments for a topic or an action. - Add a topic
You can add a topic on the Topic Management page. - Associate a topic with a product-event combination
Follow these steps to associate a topic with a product-event combination. - Select a topic template
When adding a topic, saving to a topic, or submitting a review, you can select a topic template for your new topic. - Make a topic visible to a work team
A work team is a group of users who have an interest in a set of topics. When a topic is made visible to a work team, the members of that team can view the topic and any actions defined for it. - Link topics
When you edit a topic, you can add a cross-reference from that topic to another topic by adding a topic link. - Remove a link
You can remove a link added to a topic that provides a cross-reference to another topic. - Reopen a topic
You can reopen a topic if the topic is in a closed state and your topic workflow configuration includes a transition from that state to another state, such as Assigned or Reopened. - Delete a topic
You can delete topics from the Topics table. - View the history of a topic
You can view the history of topics you created and topics you have permission to see from your work teams. - Viewing topic reports
Predefined Oracle Analytics reports are optional topic reports that provide greater detail on topic information. - Create a topic PDF or ZIP file
You can create a PDF or Zip file to document the contents of a topic and include attachments.
Parent topic: Use Oracle Empirica Topics
