Modify the display order for a field
A field can only have one display order, even if it appears in more than one context. You can set the display order of the standard and custom fields.
- In the left navigation pane, click the Settings icon ().
- In the Configure System section, click Manage Topic Workflow Configurations.
- Click the configuration's Row Action menu (), and then click Edit.
- On the Edit Topic Workflow Configuration page, click the Fields card.
- Click the Modify Display Order link.
- The dialog box lists every field in the currently assigned display order. For each field, the identifying information appears as Display name [COLUMN_NAME] (ID=#).
- Click a field to select it.
- Use the and keys to move the field up or down in the list.
- Click OK.
Parent topic: Manage fields
