Refresh an interactive signal configuration from the Refresh Signal Management page
To refresh a signal configuration for the first time, you must use the Refresh Signal Management page. However, for future refreshes, you can use a definition file.
You must have the Manage Signal Configurations and Create Data Mining Runs user permissions to initiate a refresh.
After you refresh a signal configuration, you should not edit the signal configuration.
You cannot schedule a refresh if a refresh is in progress.Parent topic: Manage interactive signal configuration refreshes
