Refresh an interactive signal configuration using a definition file
To refresh a signal configuration without logging in to the Oracle Empirica Signal application, you can use a definition file. The definition file enables you to refresh an interactive signal configuration that you have refreshed previously.
The following procedure describes how to set up the definition file for the first time.
You must have the Manage Signal Configuration user permissions to create a definition file.
Parent topic: Manage interactive signal configuration refreshes
