Specify settings
When you click Settings in the left navigation pane, the Settings page appears.
Your user permissions determine the options you see on the Settings page. For most users, this page includes only the following options:
- Change Password (available when not using single sign-on or LDAP)
- Remove Visited Status for Case ID Links
- Manage Saved Lists
- About
Settings for managing users
Settings for monitoring the system
Settings for administering the system
Parent topic: Settings and administration
