Work with actions
This section includes procedures for working with actions.
- Work with actions
An action is an activity that has been identified as contributing to the understanding or resolution of a topic. - View all actions
You can view all the actions that have been added to the topics you created or topics that have been made visible to a work team of which you are a member. - View a topic from the Actions table
You can view a topic from the Actions table. - View actions for a topic
You can view actions that have been added to a topic. - Add or view comments for an action
You can add comments to an action and view comments associated with an action. - View Action and Edit Action pages
From the Actions table, you can view and edit action information. - Edit the general information about an action
You can edit the name, description, and any custom fields defined for actions by the topic workflow configuration. - Add an action
An action is an activity that has been identified as contributing to the understanding or resolution of a topic. - Delete an action
You can delete actions from the Actions table. This option is also only available if you have the Delete Topics/Actions work team permission. - View the history of an action
You can view the history of actions you created and actions you have permission to see from your work teams. - Reopen an action
You may be able to reopen an action in the Closed state.
Parent topic: Use Oracle Empirica Topics
