Add a comment
You can add a comment to a product-event combination on the Product-Event Combinations page. All other users can see the comment. If the signal management configuration allows private comments, however, you can add a comment visible to you and superusers only.
If you are working from a multisource signal configuration any changes you make are also made in all connected configurations.Note:
Private comments are visible to only you and superusers. However, if the product-event combination becomes part of an attachment in a topic, the private comment becomes visible to anyone who can view that topic attachment.Parent topic: Focus on product-event combinations
