Step 3: Review product-event combinations for a product
- Panels of the Product-Event Combinations page
The Product-Event Combinations page enables you to review comprehensive product-event information and statistics. - Investigate product-event combinations for a product
Review and interact with product-event combination statistics. - View product-event combinations for a card or tab
Use cards and tabs to choose the specific data to display on the product-event combinations table. - Use Row Selection mode
Apply actions to multiple table rows simultaneously. - Save a modified product-event table as a new view
Save your table configurations for easy access. - Add a tab to the Product-Event Combinations panel
Use tabs to bring your signal data views to the table. - Product-event combination columns
Learn about the statistical scores for product-event combinations. - Focus on product-event combinations
Gain insight on your data with visualizations and other robust signal analysis tools. - Review product-event combinations from a multisource configuration
As an extension of interactive signal configuration, multisource signal configurations enable you to perform safety surveillance across multiple data sources.
Parent topic: Review signal information
