Investigate product-event combinations for a product
Review and interact with product-event combination statistics.
The Product-Event Combinations panel is a set of tables, accessed by
clicking a Product-Event Combinations tab. Each tab represents a view of the
Product-Event Combinations assembled from the current Refresh runs, as well as rows
from previous refreshes which have either unreviewed alerts or comments. By default
there is a tab for each active alert type. If configured, there is also a default
view tab. You can
add more tabs using the
icon on the right.
If you are working with a multisource signal configuration, keep in mind the special considerations for multisource signal configurations as you perform the actions below.
Parent topic: Step 3: Review product-event combinations for a product
