Use this process to define or edit all values for a field.
In the left navigation pane, click the Settings icon
In the Configure System section, click Manage
Topic Workflow Configurations.
Click the configuration's Row Action menu (), and then click Edit.
Click the Fields card.
Click the field's Row Action menu (), and then click Define Values.
Choose one of the following:
To add a value, click the Add Value
link.
To edit a value, click the value's Row Action
In the Value field, enter a value.
If the field you are adding is the subsidiary field in a linked pair, select
the value that this value is subsidiary to in the Link to the
parent value field.
For example, if a MedDRA SOC field and a MedDRA HLGT field are linked, you
select an SOC value, and then a list of relevant HLGT values is made
available for selection.
Click Save.
Repeat this process as needed to define or edit all valid values for the field.
Alternatively, you can save all values in a .csv file and upload the
table of values.
