View valid values for a field
To present a list of values for a field, instead of a value-entry field, you supply one or more valid values for that field.
You can define values for:
  • Standard string fields.
  • Custom string fields.
  • Custom integer fields.
You must define values for custom fields that have one of these types:
  • Linked
    You must define values for both the controlling parent field and its subsidiary field. Typically, all values for the parent field are defined before the values for the subsidiary field are defined.
  • Append-only
  • Constrained and Append-only
  • Multiple Values
  • Constrained and Multiple Values
You can also specify the order in which the values appear in the list. If the field is not required, users can select " " (blank) to leave the field empty.
To define field values:
  1. In the left navigation pane, click the Settings icon (Settings icon).
  2. In the Configure System section, click Manage Topic Workflow Configuration.
  3. Click the configuration's Row Action menu (Row Action menu icon), and then click Edit.
  4. Click the Fields card.
  5. Click the field's Row Action menu (Row Action menu icon), and then click Define Values.
    The Define Valid Field Values page provides the following information about the field values that have been defined.
    Column Description
    Value
    Value that is available for selection in the topic field.
    Link to Parent
    Value that must be selected for the parent field for this value to be available. Applies to the subsidiary field in a linked pair only.
    Order
    Number indicating the display order for the value.
