Delete a multisource signal configuration
You cannot delete a multisource signal configuration in the following
situations:
- Alerts have been generated.
- A refresh is in progress.
You must have Manage Signal Configurations user permission to perform the following actions.
- In the left navigation pane, click the Settings icon
- In the Configure System section, click Manage Signal Configurations.
- Click the Row Action menu (
) for the multisource signal configuration, and then click Delete.
- Click OK to confirm your choice.
Parent topic: Manage multisource signal configurations
