Multisource signal configuration FAQs
- How are products matched across configurations in a multisource signal configuration?
- Which configuration should I choose as the lead configuration in a multisource signal configuration?
- Can I change the underlying configurations in a multisource configuration?
- What is a connected configuration?
- How do I manage refreshes for a multisource configuration?
- What differences do I see when using Signal Review features with a multisource signal configuration?
- Why don't I see products from the secondary configurations in a multisource signal configuration?
- Why can’t I modify the column labels for secondary configurations in a multisource configuration?
- Why do I see warning messages on the Signal Review page when using a multisource configuration?
- How is auto-assigning to reviewers different for a multisource configuration?
- How does the Standardized MedDRA Queries (SMQ) option work
Parent topic: Manage multisource signal configurations
