What differences do I see when using Signal Review features with a multisource signal configuration?
When reviewing products in multisource signal configurations you see data from the secondary configurations added to the Product and Product-Event Combinations tables. You can add the columns from the secondary configurations by configuring the tables views. Data visualizations, such as sector maps and breakdown graphs, are available for both lead and secondary configurations. You can distinguish columns and menu items that refer to the secondary configurations by the prefix that matches the secondary configuration label defined in the multisource signal configuration.
See Review products from a multisource configuration and Review product-event combinations from a multisource configuration for details.
Parent topic: Multisource signal configuration FAQs
