Delete a product
You cannot delete a product in the following situations:
- There are notes for the product.
- A refresh is in progress.
- There are comments for any product-event combinations that include the product.
If you are working from a multisource signal configuration any changes you make are also made in the underlying lead configuration.You cannot delete a product from an multisource signal configuration in the following situations:
- The lead configuration or any other connected configurations are undergoing a refresh.
- The lead configuration or any other connected configurations contain notes for the product.
- The lead configuration or any other connected configurations contain comments for any product-event combinations that include the product.
You must have the Manage Signaling Terms user permission to delete a product.
Parent topic: Manage monitored products
