Edit a multisource signal configuration
Field descriptions—Edit Multisource Signal Configurations
Field | Description |
Name |
Signal configuration name. This name appears on the Signal Review page, above the product-event combinations table. |
Description |
Description of the configuration. |
Lead Configuration (read only) |
Identifies the lead configuration in use by the multisource signal configuration. You cannot change the lead configuration. |
Secondary Configurations |
Identifies the name and label of each secondary configuration in use by the multisource signal configuration.
Note: Changes to secondary configurations, including changing the label, take effect only after refreshing the multisource signal configuration. |
Default signal view |
Name of the default signal view appearing as the global default for the signal configuration. This view appears as the left-most tab when viewing the Product-Event Combinations page. If a different default view is specified for a specific product, the product's default view takes precedence and is shown when viewing that product. |
Suppress alert calculations in next refresh |
Select this option if you do not want to calculate any alerts the next time the configuration is refreshed.
Note: If you remove or replace a secondary configuration, alert types and views may still point to the previous configuration that is no longer connected to the multisource signal configuration. If this is the case, the refresh fails unless you suppress alert calculations.See Change a secondary configuration in a multisource signal configuration. |
Topic workflow configuration (read only) |
Name of the topic workflow configuration that is integrated with the signal management configuration. When this integration exists, users can associate topics with product-event combinations using the Submit Review dialog box, and topics are stored in this topic workflow configuration. Note: To change value, edit the lead configuration |
Topic product field (read only) |
Names of products in product-event combinations associated with
topics. You can use the Topic Product
Field filter when browsing for existing topics
from the Submit Review dialog box.
Note: To change the value, edit the lead configuration. |
Disable default view |
Select to disable the default view on the Product-Event Combinations page. When disabled, both the default view specified for the signal configuration and the default view specified for a specific product are ignored. |
Disable private comment (read only) |
Disable private comments setting for product-event
combinations.
Parent topic: Manage multisource signal configurations
